ANSYS Workbench ACP Post problem
Kostas Koutsoukos
Materials
GR
I am designing a composite part in ansys workbench 17 using the ACP tool. The problem that comes up is at ACP post. When I add a solution (i.e. a deformation) and I update the model in order to produce the contour of the solution, the updating bar freezes at the same spot every time, specifically at "Updating Postprocessing plots". The odd thing that I notice is that the same problem cames up running previous models that have worked perfectly before. I unistalled and reinstalled ANSYS, I runned the model in a different pc as well. Nothing seems to work. I really need some help for someone with experience on that. Thanks in advance.
