  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
ANSYS Workbench
AminCE
8
0
0
DZ
Hi
I am using ANSYS Workbench for modelling concrete beam. I have about 100 bodies in my model, and I should use commands to input the material properties to each body. When I grouped the bodies that have the same material properties, it gives me three groups. I would like to ask you: how can I assign the materiel properties to each group rather than each body via commands?
This model gives me 50 contacts between the bodies, and I would like to use Cohesive Zone Model to model the separation between the bodies so how can I input Cohesive Zone Model via commands without repeating it for each contact? because they have the same values and it takes a long time to input the properties if I input it for each one separately.
How can I see Crack pattern of concrete?
Thank you Erik and Petr for your replying
@Erik I have 50 contractions, the method using in the video it's take so long. I would like to find an easy method to do it.
@Petr I cannot access to the link that you posted
