Anyone for a beer.
I saw those years ago in Australia. Most of the cups sent down there from europe didn't down under so they had to invent the bottom filler.
That is cool technology. $0.36USD per plastic cup seems a touch high, but maybe the ad revenues will knock that down.
David
So let's replace the tin ring and magnet with a more economical, belt-fed plastic plug. I like the idea of the magnetic sealing disk being used for advertising, you could have a whole collection of buttons by the end of the night.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
These things are cool... but if you wanted to quickly fill a regular cup, perhaps you could make a dispenser with a long neck that makes a u-turn at the bottom? Lift the cup until the long neck touches bottom, pull the lever to fill, then pull the cup down & away? The only trick that's not accomplished by that method would seem to be the auto-shutoff when the cup is full..oh, and hands-free filling.
Hmm. isn't this what the hand pulled beer pump does anyway?
M
Dr Michael F Platten
usually they fill from the top of the cup...
Yeah, the head on the beers in the video was more consistent than I've ever seen a top-fill accomplish. A gooseneck insert arrangement could work, but I think that when you start filling you might shoot beer to the ceiling.
It also seems like any kind of in-place fill valve would either have a significant number that leak or a very high cost. The magnetic plug is just a brilliant idea.
David
If you really want to save time get rid of the cup, and just set your Ausie on there.
@IRstuff: LMAO
