NickParker
- Sep 1, 2017
- 445
The specification states: "The insulation system shall be completely sealed per API 546."
Generators manufactured to IEC 60034 are easier to procure, have shorter lead times, and are less expensive compared to those built to API 546.
I understand that the testing requirements under API 546 are more rigorous than those under IEC 60034, but I am unsure about the broader advantages and disadvantages between the two standards.
According to API 546, Section 4.3.5, the stator windings, including the lead connections, must have a sealed insulation system capable of passing a sealed winding conformance test in accordance with NEMA MG 1, Part 20.
If we choose not to perform the API 546 test, are there any significant disadvantages that I should be aware of?
