API 579 time used for FCA
fedefer85
11
Hello everyone.
I have a pressure vessel with an acceptable LTA and remaining life >10 years. It will be inspected in 5 years from now. I used 5 years to calculate the FCA. Should I use 10 years?
FCA definition says that is: "the corrosion allowance required for the future operational period of a component".
Thanks a lot.
Regards.
Do not confuse Future Corrosion Allowance (FCA) with "original specified corrosion allowance".
Reread API 579 and use your engineering judgment.
API 579 is clear and easy to understand.
I didn't confuse FCA with CA, is the definition provided in API 579. And I've read the code and decided to use 5 years for FCA. I just asked if anyone would use 10 years instead of 5.
API 579 do not establish inspection intervals. You decide. Several countries establish them.
You are confusing everything, read my thread and my reply again: I didn't ask for the frequency of inspection. I'm asking for the time used for the FCA.
Thanks anyway.
I would have specified something a little beyond the 5 years to your next inspection interval (because inspection intervals often don't work out that cleanly). I probably would have run a series of times to calculate FCA, in order to determine the time-to-failure.
@ fedefer85
If the remaining life >10 years why it will be inspected in 5 years from now? Your engineering judgement is not clear.
If you have already decided on a 5 years interval, if you have read and understood API 579, why are you asking a question for a 10 years interval?
Not sure now?
You can inspect every year if you want. In this case you will be fired at my company.
Am I the one who confuses everything?
I take my time to help you.
OMG... It will be inspected in 5 years, without a doubt. WHAT I AM ASKING IF THE FCA IS BETTER TO BE CALCULATED 2*INTERVAL OR NOT! It's simple as that the question. And I wouldn't work with you, thanks anyway.
Avoid further replying.
Good luck
