eberger
As per API 650 clause 5.12 tank anchorage, table 5-21a shows uplift load calculation formula including seismic case as U=(4xMrw/D)-W2(1-0.4Av).
The load per anchor equation (tb=U/N) appears to assume that all anchors will share the uplift load equally. However, if I have a cylindrical tank with equally spaced anchors, and a moment in one direction, won't only half( (or less) of the anchors be acting in tension, while the other half of the tank will be in compression? How does tb or N (# of anchors) account for this?
