Hi guys. Could someone please point me to the section in API 650 that establishes the allowable overpressure beyond the tank MAWP, for example during venting? A search of posts here turns up "For API 650 tanks, overpressure must not exceed MAWP of the tank. That means the set point should be lower than the Design pressure." but I couldn't find that in 650 or in API 2000. The only thing I find in 650 is Appendix F, and 2000 refers you back to the applicable tank design code.
Thanks very much in advance! Pete
