RBKN
- Apr 18, 2018
- 17
I am designing an API 650 tank for the first time and have loads given for a 4" nozzle with RFWN flange. Is there a section in API 650 giving guidelines to select the class of flange to be used?( if it were ASME section VIII Div 1 I would have to use a 300# under these conditions) I looked at Appendix - P but I cant see how it will help in selecting which class of flange should be used? I want to check if I can get away with 150# by API 650 standards.
