I am updating a spreadsheet for API 650 tank foundation design. I've posted a couple questions and thanks to those who have provided your answers.
Here comes the 3rd question.
With regard to foundation stability (E.6.2.3), API 650 requires to check the stability under slab moment against the resistance from TOTAL weight of the tank content (plus weights of tank, foundation and soil), whereas in determining anchorage (self-anchored or not) only the portion of content directly above the effective annular ring is considered. How can it be justified that the content in the middle of the tank contributes to the foundation overturning stability (suppose in case of ring wall foundation the content in the middle doesn't bear on foundation)?
Considering an extreme case, if the tank is NOT self-anchored, how to make sure a tiny foundation is able to hold down the tank?
