Dream91
Chemical
- Aug 21, 2017
- 25
As per API 650 , Nominal thickness of roof plate shall not be less than the greater of D/(4.8*SIN PH)*ROOT(B/2.2)+CA, D/(5.5*SIN PH)*ROOT(U/2.2)+CA , 5 mm
My question if 5 mm is the greater shall we add the corrosion allowance ( CA ) so it will become 8 mm?
