Aloni
- Sep 7, 2013
- 36
Hello everyone,
I need to design a tank made of TiG2 ,
The tank’s dimensions are a diameter of 1.2m and a height of 9m. The design pressure is hydrostatic, and the design temperature is 90 degrees Celsius. The tank has a flat bottom resting on concrete.
Intuitively, I considered using the API 650 standard. However, upon review, I found that titanium Grade 2 is not included in this standard, meaning it does not cover this material.
I would like to know if it is possible to use the existing formulas for calculating the bottom thickness from Annex AL (which pertains to tanks made of aluminum but apply the values from ASME Section II, Part D.
if it is not ,I would appreciate guidance on how to perform this calculation according to ASME Section III, Division 1.
Thank you in advance for your assistance.
Aloni
Aloni
