Adam001
- Apr 19, 2017
- 28
In API 650 item 5.1.5.9 e , there is "Roof-to-shell connection details per Figure F.2 are permissible provided that the design effective area (crosshatched
section) is greater than or equal to the design effective area provided by the minimum top angle size listed above " , I know how to calculate the available area according to F.2 but I don't know how to calculate required area or minimum area according to this wording , the code doesn't refer to equations but in appendix F item F.5.1 there is an equation but for max pressure only so I got confused so how can I calculate required area ?
