Looked at too many Appendix B curve fits, so the spreadsheet jumped out as weird, and I dug into it a little.
[ul][li]Very suspicious that the elevation for locations 1 and 20 aren't closer together. Everything looks great except that there's a sudden 2" drop between 20 and 1. It isn't obvious from the data in rows 78 thru 97 that the survey "closed", meaning they got the same reading for location 1 when the laser was at setup D.[/li]
[li]The E value in cell E67 needs another zero.[/li]
[li]The tank height in cells D34 and I68 are different. No wonder there are different S values due to these 2 differences.[/li]
[li]The plot at cell F26 is from an external spreadsheet for some obviously different data. Same for the F38 plot.[/li]
[li]There's no place to enter "a, b, c" of clause B.2.2.4(e), so there's no way to do a best fit cosine. The plotted cosine is just an arbitrary selection. Thus the result in column M is meaningless.[/li]
[/ul]
I stopped looking at this point. Too many problems.
Make a long story short, no way anybody should use this spreadsheet as-is for an Appendix B check.
