Shafx
- Oct 31, 2019
- 7
Hello!
I want to ask about the repair procedure of Bottom annular plates.As the integrity report recommends only bottom(All plates) removal.Now the first problem is that how to cut the shell to bottom joint?
And 2nd problem is that contractor has asked to cut a 2m(width) and 1.5m(full height of shell) temporary door in 1st shell course for the purpose of IN/OUT the plates.I suggested them to cut the make-up piece but there was no access for crane work so that suggestion went in vain.Now i have asked contractor that come with a code reference because yor are going to cut a door in shell(cutting one old vertical seam and one new vertical seam).so adding a new vertical seam in First Shell course.
Suggest me the possibilities.???
