Just wondering if anyone has come across the adaptation of the ASME Section VIII, Div.1 Appendix 2 flange analysis for an unrestrained expansion joint in an anchored piping system. In this situation, the loads on the flange are different because much of the thrust that is pulling the flanges apart is in fact held by the main anchors on each side of the expansion joint rather than the bolts.
Any info would be greatly appreciated.
SG
SG
