Syahar1975
- Feb 3, 2011
- 224
Dear Tank Buiders,
A tank designed as per appendix F has an internal pressure 0.5 PSI.
We have to air tested this tank as required. We are planning to use a water manometer to measure the air pressure above the hydrotest water.
From google we have 0.5 PSI = 351 mmH20.
Is the above equation still remain the same for ambient temperature 30 Celcius.
Or there is an adjustment factor to be considered.
Syah
Syah
