AleksaBgd94
Hi everyone,
I am trying to model a composite (steel-concrete) beam-to-column joint and to analyze its behaviour under concentrated moment.
I applied a moment at the end of the beam section, to act in the center of inertia of composite section. The center of inertia is defined as a reference point (reference point is a control point for the coupling constraint).
The results concern me because:
steel section and concrete above it deform together, but stresses only appear in the steel section.
Do you have any tips - how to 'activate' the concrete above steel section?
I used C3D8R elements for steel section and C3D4 for concrete part of the assembly. The only interaction between two parts is general contact (hard contact and friction are assigned).
If you need more information about the model and the joint, please write.
