Most PV solar sites I have provided the relay settings range from 20-300 MW with a collector substation feeding multiple 12-34 kV circuits. At the substation there is typically a wye-delta-wye transformer without a neutral ground resistor. Discussing coordination with another engineer at a conference, most of the sites he worked with have an NGR in the design.
I have a couple questions to start-
1. Is it common for PV sites to have the NGR on the Wye-Delta-Wye MV side?
2. What steps should I take to evaluate suggesting an NGR or suggesting NGR be omitted?
