I have an 100 yr old house that only has 1 layer of 3/4" T&G flooring. There is no Sub-Flooring. They are wanting to sand it again but I cautioned them about losing strength due to repeated sanding. Are there special design values for 1" or less SYP or does everyone use the NDS for a design check such as this. I have used NDS before but most info in NDS is 2" or thicker lumber.
