Are these spacers needed between roof trusses in my attic
Yrok
Aerospace
Feb 12, 2025
I am trying to add additional storage to my attic and these 2x4s are at an awkwardheight.. Are the circled 2x4s needed? They look to me like they were for getting proper spacing between the trusses and nothing more. There are 3 nails shot diagonally through the bottom of the horizontal 2x4s into the vertical trusses. If they are by some chance structural, can I cut them out and reinstall them higher?
Thanks for the help.
Silly structure; attics are for storage.
Hire a structural engineer or decide for yourself to gamble and cut it. Nobody here is going to risk their license by telling you it’s ok to hack wood without inspecting the building. Moreover, do you really want to be the person that defends this action with, “well, the internet told me it was ok”? This isn’t tele-engineering for homeowners. Answers cost money!
They maybe there to reduce the buckling length of the truss webs as would be noted on the original truss drawings. Not a great installation but probably doing something. You could likely remove them is you sistered up each affected web. I would be careful of hoarding a bunch of stuff up there though.
No, you can't just cut them out. There would be reinforcement required. I'm of XR's opinion and they are certainly necessary. There are other things that can be done, but as ANE91 said that would need to be decided by a structural engineer on site and being paid for their services.
Those vertical struts are actually quite thin and slender and in certain roof loadings my guess is that they are under compression forces. Without them, those long slender bits of wood can easily bend and buckle. Once one bends then more load goes onto its neighbour which then bends more ....
They are probably at mid height to reduce the strut length for buckling. Removing them is a bad idea. Moving them is equally bad as now one length exposed to bending is longer than the other and you don't know what the critical length is.
Be careful how much load you add to the loft floor. Modern trusses are designed to the minimum sizes and anything more than maybe20 psf could easily lead to overload. Unless you've got clear designed load limits from the truss designer, be very careful. IMHO.
Thank you to those who actually provided constructive feedback and not just insults. The only things getting stored up there are empty boxes (Big screen TVs and other large expensive electronics are much easier to safely transport in their original packaging) and seasonal decor stored it plastic storage bins, i.e. nothing I can't easily and safely carry up the attic ladder myself. The existing space provides access to my air conditioner units and I don't want to block this access with storage bins. I intend to lay down 2x6's across the existing ceiling joists, add additional loose insulation between the 2x6s and topping with plywood without compressing the added insulation. A couple of the 2x4s in the picture are just at an awkward height to allow access to the additional storage area. I will add 2x4's roughly 1 ft higher than those in the way before cutting them out and may also add additional ones at a lower height which should more than make up for what is there. I'll leave the others unchanged.
The other way is possibly to use loft insulation board stilts like these https://www.ecohome-insulation.com/product/loft-storage-stilts/ which reduce the weight of the floor. A bit fiddly, but worth it as you can add another 150mm insulation very easily. Moving them by a foot should be fine, but it's at your risk. In general don't mess about with trusses - they are designed to fine margins and shouldn't be messed about with.
These forums are not really meant for non engineering / homeowner type questions so some people get a bit guarded as we don't want to be seen as a source of free engineering based on nothing more than a couple of photos. If you're aerospace it's maybe like someone with their own plane asking you if they can cut a few holes in the fuselage??
Next time maybe try the hobbies forum.
