Arrangement specific constrains in NX 1
Aerospace
Feb 21, 2012
15
I have assembly which is fully constrained condition. Need to create arrangements to show open/closed/rotated condition of assembly. Since the assembly is already full constrained how to create arrangement specific constrains?
Delete the assembly constraints that are preventing the movement desired for the arrangements, then when changing the arrangements the assembly will move smoothly.
Jerry J.
UGV5-NX1961
You can edit the constraints to make the arrangement specific. That way, when you toggle between "open" and "closed", the constraints will turn on/off as needed.
-Dave
NX 12, Windchill 11
If you right click on the constraints you can make them arrangement specific, it will also change the icon next to the constraint to show it is arrangement specific.
Thank you all for your responses
