Array Help
RYANspaceHall
I am trying to hide cells that are in my array. I am new to VBA so I am having a little trouble. My code is below. Thanks in advance! My array is in columns E-S and the cells contain letters E-S in it.
Private Sub Worksheet_Change(ByVal Target As Range)
If Target.Address = "$A$3" Then
Dim i As Long
i = 0
Dim MyArray() As String
For i = 0 To 14
MyArray(i) = Range("E1:S1").Value
If 0 <= i <= 14 Then
If (Target.Value) = "yes" Then
Columns("MyArray(i)").EntireColumn.Hidden = True
ElseIf (Target.Value) = "no" Then
Columns("MyArray(i)").EntireColumn.Hidden = False
End If
End If
Next i
End If
End Sub
Here is the updated version. I am probably over complicating it. My goal is to have one group of cells close if it has data and have the other group of cells open if it doesn't have data. (The data is 'RUN' in this situation) This will search and see if the column (j) has data in cell(4,i). If so then j will close The user types in 'yes' or 'no' to open and close it. If there is an easier way let me know.
Dim i As Integer
Dim j As Integer
i = 5
j = 0
For i = 5 To 19
For j = 0 To 14
MyArray(j) = Range("E1:S1").Value
If (Target.Value) = "yes" And Worksheet.Cells(4, i).Value <> "RUN" Then
'I want MyArray(j) to be the corresponding letter in my array
Columns("MyArray(j)").EntireColumn.Hidden = True
ElseIf (Target.Value) = "no" And Worksheet.Cells(4, i).Value = "RUN" Then
Columns("MyArray(j)").EntireColumn.Hidden = False
End If
Next j
Next i
End If
End Sub
Thanks for your help I figured it out.... And I didn't use an array; just over thought it.
Dim i As Integer
i = 5
For i = 5 To 19
If (Target.Value) = "close RUN" And Cells(4, i).Value = "RUN" Then
Cells(1, i).EntireColumn.Hidden = True
ElseIf (Target.Value) = "close RUN" And Cells(4, i).Value <> "RUN" Then
Cells(1, i).EntireColumn.Hidden = False
ElseIf (Target.Value) = "view RUN" And Cells(4, i).Value = "RUN" Then
ElseIf (Target.Value) = "view RUN" And Cells(4, i).Value <> "RUN" Then
End If
Next i
End If
End Sub
It would seem much simpler to place a few buttons for the user to click instead of relying on them typing some "case SENSITIVE" text.
Thanks, I have a drop down list for them to choose from.
Your macro can be simplified to the following:
Code:
     Dim i As Integer
     For i = 5 To 19
          If ((Target.Value) = "close RUN" And Cells(4, i).Value = "RUN") or _
             ((Target.Value) = "view RUN" And Cells(4, i).Value <> "RUN") Then
          else
          End If
     Next i
End If
End Sub
p.s. It's easier to see the code and structure if you indent
Thanks I will implement your code in with what I have now. I had it indented but when I copied it it left justified everything.
I am having trouble when I run this. It ran Perfect when I Set myRng = ActiveSheet.Range(Cells(1, j), Cells(1, 19)). When I changed is to shB (which is Sheet2) then I get an error, Method Range of Objects. I believe I have a problem defining the range. Just need some help figuring it out. I also understand that my code isn't efficient yet. I am still in the learning process. Thanks again.
Dim i As Integer
Dim j As Integer
Dim myRng As Range
Dim shB As Worksheet
i = 5
j = 5
Set shB = Sheets("Sheet2")
For i = 5 To 19
For j = 5 To 19
If (Target.Value) = "close RUN" And shB.Cells(4, i) <> "Run" Then
j = i + 1
Set myRng = shB.Range(Cells(1, j), Cells(1, 19))
j = 19
End If
Next j
'This part runs perfect
If (Target.Value) = "close RUN" And shB.Cells(4, i).Value = "RUN" Then
shB.Cells(1, i).EntireColumn.Hidden = True
myRng.EntireColumn.Hidden = False
ElseIf (Target.Value) = "close RUN" And shB.Cells(4, i).Value <> "RUN" Then
myRng.EntireColumn.Hidden = True
ElseIf (Target.Value) = "view RUN" And shB.Cells(4, i).Value = "RUN" Then
shB.Cells(1, i).EntireColumn.Hidden = False
ElseIf (Target.Value) = "view RUN" And shB.Cells(4, i).Value <> "RUN" Then
End If
Next i
End If
End Sub​
And once again I figured it out.
needed to be
Set myRng = shB.Range(shB.Cells(1, j), shB.Cells(1, 19))
