Hi Eng tips community,
I am working through the design of a composite beam bridge using AS 5100.6 - 2017. I understand how I would derive the capacity of a 'non-compact' composite cross-section but I am having difficulty deriving the capacity of a 'compact' composite cross-section.
Clause 6.4.3 states that:
The nominal section moment capacity (Ms) of a compact cross-section in sagging or hogging bending shall be determined as follows:
Ms = Mp
Where Mp = nominal section moment capacity.
Mp shall be determined by simple plastic theory using the following assumptions:
a) Plane cross-sections of structural steel and of concrete each remain plane
b) The effective section of the composite beam replaces an effective width of the concrete compression flange, determined in accordance with clause 4.4.1.
I am having trouble with clause 6.4.3b). There are no references in the standard as to how to derive this "effective section". Clause 4.4.1 uses the standard methodology for determining the effective width of the concrete compression flange. I have found some references to the 'effective section' in AS 2327.1 but I am unsure as to how relevant this working will be.
NZS 3404 is the standard I am familiar with. This method also uses an effective concrete deck width to derive capacities.
Can any Aussies help a kiwi out?
Cheers,
Jack.
Ms = Mp
Cheers,
Jack.
