structeng2
- Apr 18, 2016
- 38
Hello All,
I have a question regarding ASCE41-13 7.2.8.1. I am checking overturning on pre-cast panels of a steel frame building. The panels are not positively attached to the columns for in-plane/overturning - only out-of-plane. All in-plane and overturning forces are resisted at the foundation level.
As I understand the code - equation 7-5 and 7-6 can both be used to determine the net overturing on an element and whether positive attachments are required (i.e. if the overturning exceeds the stabilizing moment from dead load alone).
However, the two equations are vastly different. Assume my C1C2 = 1.4, J = 1.0 and performance level = Life Safety.
I feel like I must be missing something? Thanks for your help.
Eq 7-5 yields: Mst > [Mot/1.4]
Eq 7-6 yields: 0.9*Mst > [Mot/11.2]I feel like I must be missing something? Thanks for your help.
