We are calculating the wind force on a structure using Chapter 29 of ASCE7-10. The equations give the force as "F", which is essentially the pressure times the area of the structure. I would have taken F as equal to W for purposes of using the load combinations in Chapter 2, where we would factor F by 0.6 for most of the ASD combinations. However, F is explicitly defined as a fluid load, not wind in this chapter.
Does anyone know if it is explicitly stated somewhere that F = W when F is the calculated wind force from chapter 29?
