Does anyone have experience with the Thermal Comfort - Graphic Comfort Zone Method? The temperature range they suggest to achieve thermal comfort seems inaccurate. See attached link, page 7-8.
That's really my main question. Typical cooling design set points would target 72 as a maximum design temperature. This has 74 as a minimum cooling temperature with 0.5 clo. I know I get really hot when a room is 74, even with a t shirt and shorts. Even at 0.2 m/s air speed, 74 as a minimum seems high.
I am trying to achieve the LEED Thermal Comfort Credit. It can be achieved, and then some, because the target cooling temperatures are lower than listed here. However, I was just curious if someone could provide further insight into this chart.
