ASMA BPVC VIII DIV 3 Local Criteria KD-232 1
SiggiN
Marine/Ocean
Mar 18, 2019
33
Hi all!
I currently following the steps in KD-232 "Protection against local failure"
In equation "KD-232.3":
What exactly is the different delta terms? I cannot find an explination
My understandaing/ gut feeling is that e.g. Delta_epsiolon_p,11,k is the difference between principal plastic strains between increments. I.e.:
Delta_epsiolon_p,11,5 = epsiolon_p,11,5-epsiolon_p,11,4
Any help would be appriciated :)
OP
Yes, but your notation isn't strictly correct. It shouldn't overlap between load steps 4 and 5.
Delta_epsiolon_p,11,5 = epsiolon_p,11,5End -epsiolon_p,11,5Start
Δε11,k = nΔε11,k - mΔε11,k
Δε11,k = endΔε11,5 - startΔε11,5
where 'k' is the step being assessed (say the 5th step), 'n' is the end of the step being assessed and 'm' is the start of that step.
See Equation 5.28 of Div 2 for a similar equation.
