ASME/ANSI
yongheekim
14
CA
I am a little bit confuging to use ASME and ANSI Code in specifications.
When we use these codes in specifications, I want to know about exact use of these codes,for example, ASME/ANSI B.31.3 is correct or ASME B 31.3 is correct? otherwise both of them can be used ?)
In addition, in case of flange ratings (for example ASME B.16.5 CLASS 300 RFWN or ANSI B I6.5 CLASS 3OO RFWN}
YONG H.KIM
It depends on the date of issue - more of the standards are "ASME" now that were formerly ANSI or ASME/ANSI
