Chandra2021
- Jun 23, 2021
- 3
We have a situation where a 3/4" NPS Flange with a threaded hole is connecting A 3/4" valve to an Instrument tubing. The tubing is 1/2" NPS Size.
One way to connect this Flange to Tubing is to use 3/4" to 1/2" Adapter. Another suggested solution is to bore 1/2" NPS Tapping / Thread in the Blind Flange.
As per one opinion, we can have only 3/4" NPS threaded Hole on 3/4" NPS Blind Flange as per Column 1 of Table 8 (ASME B16.5). If we provide 1/2" Thread on this Blind then this will not ASME flange anymore. If the 1/2" tapping is required, we need to carry out the necessary calculation to prove, it has the necessary strength at required fluid pressure. And obviously, this will be a non-standard ( Special) piping component.
Counterview to above: Table 8 in 16.5 does not talk about (It's silent) the size of the threaded connection on threaded Blind. Hence, we can tap a 1/2" NPS thread in this Flange.
My intent is not to make this a special item but to use Standard ASME Pipe Fitting. Please provide your interpretation of Table 8 on this issue.
