ASME B16.34
eduh
Industrial
Nov 27, 2008
Where can I find a free version of the ASME B16.34 code with the pressure/temperature ratings for class 300 and class 600 flanged steel valves?
Check with your local university library.
If you're looking for something any other way - that would probably involve copyright infringement, which is something that your engineering colleagues will not tolerate.
Just get your employer to buy the standard - - it's only US$145.
TGS4: Excuse me, I am going tu put the question something diferent: Would a class 300 steel valve resist a working pressure of steam at 25 kg/cm2 and 400 °C? If so, what would be the maximun working pressure at that temperature?
