ASME B16.5 Tolerances
oguzzz
14
What is the tolerance for inside and outside diameter of machining spiral wound gasket surface due to ASME B16.5 (For 6” nozzle). I saw exact measurements without tolerance regarding standard.
Thanks.
oguzzz, you are talking about the raised face, correct? It is addressed para 7.3 Facings (per 03 Ed).
Mike
Correct, I mean raised face. Thanks for quick reply.
Regards.
