ASME B31.3-2016 PWHT Exemption
JARivera1
7
Table 331.1.3 Exemptions to Mandatory PWHT; simple question: fourth column header referrers Notes (3)-(5); it is mean that notes 3, 4 and 5 apply? to me yes, but may be a gap for somebody that 3 and 5 only; normally when is not well applied; if the designer has specified PWHT in the piping specification; this can not be waived specially in LTCS; any advice is welcome
You are right. Notes 3, 4 and 5, all apply.
Note 4 states that if the PWHT is specified by a Designer or WPS, exemption to PHWT is not allowed.
The code is for minimum conditions. Note (4) is obvious and should be deleted.
Thanks GD2 for your feedback, I will post the follow up, I am doing to a field case
Thanks for your feedback r6155.
Believe or not there are CWIs that skipped the obvious requirement
By the way,is my understand right for the PWHT exemptions for P-No. 1 material in table 331.1.3
a)thickness>25mm:preheat of 25℃ + multiple layer welds
b)thickness 5~25mm:multiple layer welds
c)thickness ≤5mm:not mentioned in the standard
