I would like to design an argon gas recirculation system where the fluid temperature will not go beyond 40 [sup]o[/sup]C. Maximum pressure (Design pressure) of the piping system will not be more than 1000 mm of water column. The piping system comprises of 1/2-inch, 1-inch, 1-1/2-inch and 2-inch seamless pipes connected to each other by butt weld fittings (elbows (long radius), concentric reducers etc.). for such application, can we recommend (or insist on) X-ray radiography of welds or qualification by only liquid penetrant examination is sufficient. ASME B31.3 2014 341.4.1 (b)) suggests 5% random sampling of welds for each pipe lot and subjecting them to radiography.
Can I get some more clarification on the application of B31.3 for such piping application? Total number of weld joints in this case is not more than 100.
Thank you
SGH
Thank you
SGH
