ASME B31.3 ELLIPSOIDAL HEAD CALCULATION
vishnuyash
As per ASME B31.3 ,design of closures section 304.4.1 .
Closures can be designed as per ASME section VIII Div 1 .
For designing ellipsoidal heads, reference is provided in ASME B 31.3 (table304.1.1) as UG-32(d) in ASME SEC VIII Div 1 , But UG-32(d) is actually intended fro designing torrispherical heads ,
can any body help to clarify the aforementioned
Which Edition are you working with? In the 2015 Edition of Section VIII, Division 1, the head rules were renumbered. What was UG-32(d) is now UG-32(c).
I am using 2019 edition of div 1 and 20 edition of b 31.3.
I know it is updated as ug 32(c) but refernece made in b31.3 is still ug 32(d)
vishuyash- I have notified the B31.3 Committee Chair and the staff secretary of this inconsistency. In the meantime, I think that good engineering practice would be to use the actually-applicable paragraphs in Section VIII Division 1.
Thank you for pointing this out.
