ASME Data Reports
GemmellG
Materials
Jun 28, 2012
89
Working on a Recovery Boiler (Designed to ASME Section 1) Received boiler feeder tubes that came with ASME Data Report P4A & have ASME PP mark applied. Its my opining that feeder tubes are Boiler Proper as-per ASME Section 1 (PREAMBLE) & should have ASME S Mark applied & a P4 Data report supplied.
If you have the necessary MTCs, you may let it pass.
Still doubtful, go for a chemical composition (not PMI) and other mechanical tests in a reputed lab.
DHURJATI SEN
Kolkata, India
