ASME hydrotest thickness calculations 2
Seeker88
22
Good afternoon folks,
I would like to ask a question if possible please relating to the use of ASME VIII Div 1 for calculating component thicknesses at hydrotest.
We are currently designing a shell and tube heat exchanger to ASME VIII Division 1 and the design pressure is 2980 psi on the shellside of the unit. We perform all of the usual calculations for the shells, nozzles, tubeplates and tubes and all the thicknesses seem to fall in line with what we would expect. The tube thickness under the external pressure of the shellside stream is required to be 2.4 mm.
At hydrotest (3874 psi) we are utilising 90% of the yield as the allowable stress and the thickness sees quite an increase compared to design. Even with the increased design stress the tube thickness increases to almost 2.72 mm
Added to this is a client requirement to also manufacture to the PED where the hydrotest factor (1.43) increases the test pressure to 4,261 psi. However, this increase in test pressure results in a huge jump in the tube thickness to 3.5 mm (an increase of 28% in thickness for a corresponding lift of 10% in test pressure).
One suggestion from our engineers is that we are really in the wrong territory using Div 1 for thickness calculations above 3,000 psi. Indeed, when our engineers actually perform the calculations to Div 2 (using Div 1 stresses) the tube thickness at the increased test pressure of 4,261 psi is only 2.3 mm.
Am I being too simplistic in how I seem to be selectively using the codes or is there logic in the fact that above the 3,000 psi we are so far away from thin shell theory that we can expect calculations to produce disproportionate effects.
I do hope this makes sense.
Charles
My two cents:
ASME VIII-1 does not include any statement regarding the "90% of the Yield method" Therefore, one can use 95% or even more if he want to.
You just have to make sure the there will be no visible permanent distortion which is likely to occur when the stresses are entering the Plastic area.
As for the 3,000psi issue, yes, you may use ASME VIII-2, but keep in mind the VIII-2 has other requirements regarding the allowable stress during the hydrostatic test.
Take a look at ASME VIII-2, 4.1.6.2.
You haven’t provided sufficient details yet to get decent advice. What are the MOC’s of the various mentioned items? What’s the design temperature? Keep in mind that the PED also requires 1.25 times design pressure times a factor of design condition to ambient. That may even give a higher test pressure.
1.43 is just PED’s way of going to a factor 1.5 and reducing it by 5% safety margin; 1.5/1.05=1.43.
Huub
- You never get what you expect, you only get what you inspect.
Seeker88
Generally the highest pressure is on the tube side, can you change it?
Hi folks,
Thank you for the replies. It seems from some of the replies that I did not phrase my question correctly.
Design pressure is 2980 psi, ASME test pressure is 3874 psi and PED test pressure is 4,261 psi. I am not seeking to calculate or check the test pressures as these have already been done by an AI. What I am really asking is if it is feasible to use Div 2 calculations when the test pressure is above 3,000 psi? For every psi above 3,000 psi I am getting a disproportionate rise in material thickness required. With Div 2 calculations I am getting a much more realistic answer.
I just thought that I have gotten too far away from thin shell theory (shell pipe is 34 mm thick) so should I be using Div 2 calculations as long as I follow all the other requirements of the same division?
Thank you for your help
Charles
Where will this HEX be used/located? What jurisdiction applies there? Since you mentioned PED, I assume it'll be in Europe. In that case, there's no (local or national) legislation that binds you to either div 1 or div 2, so in that case, you'd be free to go with div 2, provided you follow that division in it's entirety, e.g. as IdanPV mentioned.
Huub
Seeker88
The design pressure is 2980 psi and you don't have to calculate anything with the test pressure. You can use ASME VIII Div 1 or 2 with 2980 psi, and nothing else.
You are confused.
Never, under any circumstances, should you change your thickness for a test condition.
