I have to make the calculation of a coke drum thikness at the conical section.
1.design Temp. 480 deg celsius
2.design pressure 6.158
3.halh apex angle 30 deg
4.diameter 9800mm.
now from asme II part D table 1-A the value of the maximum allowable stress is 14.22 ksi at the designed temperature converted in barg it gives 980barg the final thickness is 35.7mm.My result is 36 mm.
the manufacturer has calculated 34.9mm because it takes the maximum allowable stress from the ASME METRIC and it gives 1002barg.His result is 35mm.
he wants to stand on his calculation!
Who is Right?? and why??
tank you very much
4.diameter 9800mm.
tank you very much
