Does anyone have a link to a website that I can get a descriptive layout of an ASME Code hydro-test area. I've looked through ASME PTC-18-2002, and all it has is technical information and guidelines.
The company I work for builds Fluid & Heat Recovery systems such as booster pump packages and heat exchanger packages. We run-test all of our packages in-house prior to shipment, and I'm wanting to know if we can do anything to show that our tests are acceptible to ASME Code.
Thanks in advance
Thanks in advance
