Vitalis 1977
Hello everybody, greetings from Greece.
I would really appreciate your replies on the following matter which troubles me a lot.
During bidding phase of a project, client requested for an ASME VIII Div.1 vessel c/w with internally welded perforated plate to be ASME "U" certified and also "the whole vessel" to be "calculated" under given cyclic loading (fatigue).
Section VIII division 1 allows the designer to choose the best method that the Authorized Inspector will agree to, for conditions not covered specifically in the Code. For instance, for regular fatigue, ASME Section VIII div 1 does not provide a method to perform the calculations, but U-2 and UG-22 require the designer to account for their effects. ASME VIII div.2 part 5, (design by analysis) provides fatigue evaluation for components subjected to cyclic operation on the basis of the number of applied cycles of a stress or strain range.
My queries are the following:
1)Should we inform potential client that vessel will be ASME "U2" certified (not "U") and its design code will be ASME VIII Div.2 ?
2) Neither PVELite, nor Autopipe vessel software takes into consideration internally welded perforated plate as part of the whole assembly when vessel is analyzed as per ASME VIII Div.2 under fatigue loading. I assume that special FEA software has to be utilized for this component and separate report will have to be issued. This way the " whole vessel" calculation requirement is not covered.How can i overcome this issue?
3) If FEA software is applied for the calculation of the whole vessel (including perforated vessel)under cyclic loading and since FEA software does not take under consideration ASME VIII Div.2 requirements, what will ASME inspector expect from me in terms of design calculation reports in order to issue ASME "U2" certification?
Please provide assistance on these complicated (at least for me)issues since I'm in a big confusion.
Thank you in advance.
