MchA
- Dec 5, 2023
- 20
Hello All,
I'd want to show a doubt that comes for standard forgings and large forgings, in particular regarding carbon steel at hight temperature and low temperature.
Considering the ASME SA-350, that specification covers carbon and low alloy steel forgings, requiring notch and toughness testing for piping components: in ASME II Part.A: in particular this specificatio covers flanges and forged fitting and valvles for low temperature service, made to specific dimensions, or to dimensional standard, such as the ASME and API.
I'd like to ask you if "specific dimensions" include also tubesheet and girth flanges, or large product in general (considering also the fact that in the title this materials appears for piping only). That because, considering the material ASME SA-765 "Standard specification for Carbon Steel and Low Alloy Steel", that specification explicitate tube sheet, covers, channels barrels and integral forged channels, so seems to fit better than ASME SA-350 for large products. We usualy order flanges with specified dimension made by ASME SA765 for the reason above and standard forgings made by ASME SA-350, althrough "specific dimensions" for ASME SA-350 might include parts with dimensions specified by the purchaser.
Do you have any excperience with that? Which might be the best choice?
This difference is better explicitate for ASME SA-105 where that specification include "flanges, fittings, valves and similar parts ordered either to dimensions specified by the purchaser or to dimenional standard such as the MSS,ASME and API. Made product by this specification are limitet do a maximum weight of 10 000lb,; large forgings may be ordered to ASME SA-266. In this case, it is explicitate that tubesheet and hollow cylindrical forgings for pressure vessel shells are not included within the scope of this specification". In this case we use ASME SA-266 both for tubesheet and for girth flanges.
Is that concept extendible also for ASME SA-350 and ASME SA-765?
Thank you in advance,
