ASME SB-209 Aluminum
John Beach
1
For my project, I think I should specify Aluminum Plate per SB-209, but cannot find a copy of SB-209. Are there any (any at all) differences between ASME SB-209 and ASTM B-209? From searching the asme.org site and others, it appears the only way I can get a look at SB-209 is to buy ASME B&PV Section II for $700 or so.
John Beach, you make no mention of the nature of your project, but, if you are intending to produce work to the ASME pressure vessel Codes you must have possession of / access to the governing documents.
ASTM B209 is available for purchase as an individual document.
Mike
Please note that SB-290 is identical with ASTM Specification B209-10 except for an editorial revision to 20.1. Certification and a test report have
been made mandatory.
