I'm currently qualifying welders to welder procedure with the following variables
-A-516 70 (P1) (1/2" thk plate)
-SMAW (F4)
-3 postions (2G / 3G / 4G)
I plan on testing the welders on a 12" pc of plate. There will be approx. 3.5 inches of each position.
No where in the code can I find how much length of each position is required if the NDE method is volumetric.
I see in QW-302.2 that 6 in (150mm) is required per process, but not position.
How much lenght of weld is requried in each position when Volumetic NDE is performed on welder qualification test.
thanks in advance..
-SMAW (F4)
thanks in advance..
