EngineerEPC
Dear All,
For the dished covers shown in 1-6(b), 1-6(c) and 1-6(d), joint efficiency factors are not required as per code.
For dished cover as per 1-6(c), it seems possible since such type of construction will mostly involve a forging.
The covers for 1-6(d) will be formed as far as possible from a single piece of plate without any weld joint. if that is not feasible, then we need to do RT of the same.
Kindly elaborate the consideration by code for not considering joint efficiency factor.
Thanks and regards
Thanks and regards
