Question 1. If I had an ASME Sec VIII div 1 vessel with two nozzles, one at each end, and a small (<1") copper tube that connected between the two nozzles externally, would that interconnecting tubing be considered in scope?
Question 2. Given the same arrangement as question 1, now with a tee in the copper tube that then connected to a separate pressure vessel. Would the boundary end at the nozzle connections, or at the tee connection?
