ASME Section II Part D Table 1A note G4 interpretation 2
Trebormech
14
Hello, fellow engineers.
Regarding note G4 in ASME Section II, Part D, Table 1A, could somebody please tell me what the phrase "are enclosed within a setting" means?
Thank you.
Trebormech
Trebormech,
You may have uncovered a typo - they may have meant to say "are enclosed within a shell" since they allow higher allowable stresses, and they're referring to Sect 1 applications.
Thank you MrBTU.
So, would you consider tubes that are within the casing of a boiler, such as a gen bank tube, to be "within a shell"?
Gen bank tubes are certainly a Section I application, but I am wondering if this implies some additional form of restraint or enclosure (like refractory).
What you suggest makes sense though.
Thanks.
Trebormech
G4, last sentence about the joint efficiency factor is a little puzzling to me. Is is one below 850? If not, must another value be applied?
Mike
Does anyone else have some insight into what the phrase "are enclosed within a setting" means in note G4 of Section II, table 1A?
Thank you.
API 560 Defines "setting" as "Heater casing, brickwork, refractory, and insulation, including the tie-backs." Some of the references to setting in Sect. I also imply that it is the external walls or enclosure of a boiler.
