YuJie_PV
- Jan 19, 2017
- 143
hi,all,
i encounter a problem regarding to determination of MDMT per UCS-66.
it's nozzle welded into shell. the nozzle and shell are evaluated based on their governing thickness, and UCS-66 curve respectively. i am clear with it, just how to deal with the tg1,tg2,tg3 in figure UCS-66.3(b). which curve shall be selected for their calculation of MDMT for the welds? for example, in case of tg1, select nozzle's or shell's curve?
i am just confused. the base metal's MDMT is already evaluated, why still need to consider the MDMT of weld? what's the consideration behind the requirement in the Code?
Thanks in advance
Thanks in advance
