See attached image. My question is concerning the design of the pipe which is to be welded into the ID of the single tap pad flange. I'm thinking that the developed opening should be taken as the ID of the flange. The pipe needs to pass UG-45 calc, and pipe-to-flange welds should be per Fig. UW-16.1, sketch K.
Am I missing anything?
Thank you!
Phil
