Mech_ash19
What analysis method do you typically use for considering External Loads on Standard ASME B16.5 Slip-On Flanges. This article nicely summarizes the analysis options that are typically used for standard flanges. I assume the code method does not apply for Slip-On flanges since the code explicitly states that the listed method is for Weld Neck Flanges. Kellogg Equivalent Pressure method seems very conservative. Is there any one method that is preferred for Slip-On Flanges? Does anyone know if there is a plan to include requirements in code addressing method to use for Slip-On flanges with external piping loads? Any guidance on this will be greatly appreciated. Thank you.
