Sachin Pawar
Hello All,
It seems UG 44 rules from ASME VIII-1 are based on metallic gaskets as UG-44 (a) gives reference of ASME B 16.20 only and not ASME B 16.21. Alsi UG-44 (b) states that The assembly bolt load must comply with ASME PCC-1, Appendix O; This method was developed using a spiral wound gasket. How to apply UG-44 rules for a non metallic gasket with some modification in formulae or may be by reduction in Fm factor? Or is there any other method to be applied?
Please share your thoughts.
Sachin
Sachin
