I am doing reinforcement pad calculations for nozzles with 0.05MPa design internal pressure with ASME VIII - Div. 1 2017.
My input data from client specifies a test pressure requirement of 0.15MPa internal pressure (I know its hydraulic test).
Should I consider 0.15MPa or 0.05MPa in UG-37 reinforcement pad calculations?
